How do I fix my 160gb iPod classic?
I got done using my ipod, flipped it to hold and removed it from my audio jack in the car. After a couple hours I returned to my vehicle and the Ipod has no display and will not play. Returning home, I plugged it in to ITunes 10 which doesn't read it in the library yet says that it cannot update server cannot be contacted, not compatible with this version of ITunes. I checked for new updates (even though I updated 2 days ago to 10) and tried again. Same results. I hear the plug in tone followed immediately by the unplug tone, and itunes displays the same. Ipod does not read in windows under my computer either. I then attempted Apples 5 R's but cannot perform most because of this problem. From here I downloaded ITunes 9 (last version I successfully synced with)and attempted all of my steps again with the same results. All attempts were made with the hold button on and off just in case. My problem step-by-step:
1. No active display
2. Plug in: plug in then plug out noise
3. Won't read in My Computer
4. Won't read in Disk Management
5. Cannot enter Disk mode
6. Will not play music
Please help!
この質問は役に立ちましたか?
1件のコメント
By the way, ipod is fully charged. Before this problem, I was having an issue with syncing. The sync would stop part way through and I would have to resync. Also, during play the ipod would add 5 seconds to the middle of a song from the middle of another, and similar mixing problems. These were sporatic and I am less worried about this. I am simply putting the information up in case it is relevant.
Chad さんによる
