What cost to replace barrings in washer
How do I know if barrings are bad
Your machine would be making a loud noise:
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer.
このアンサーは役に立ちましたか?
try only punting half a load in until you fix it, or get a new one. that is what i have to do with my washer.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 44
