My USB-C ports don't have Amperage, only 5.29 Volts. Nothing works.
After I plug my Macbook charger in a USB-C Hub the ports stop working well. They only can charge the Macbook but they cannot detect any other device I plug and bring only 0.05 A and the correct 5.29 Voltage. Can anyone help me? Thanks.
To be clear, the battery is not full during this charge attempt? Also, where are you taking the readings from?
AdminAnonymous さんによる
The Battery charges and works correctly, I'm measuring with an USB Tester. All the ports are with the same problem, now sometimes it power off alone or freeze.
Siegfried Stahl さんによる
