Black & White screen
I have an iPhone 6 water damaged. It cleaned and turns on now and working fine. Only problem is the Picture on that is Black & White and there is no any colors . Anyone had this problem before?
Please help
この質問は役に立ちましたか?
Please help
この質問は役に立ちましたか?
Have you tried replacing the screen at all? Parts usually get damaged when exposed to water. Also you should test the rest of the phone’s functionality to make sure you don’t have another part that is not working properly. Another think you want to do is disassemble the whole phone and let each individual part dry. After that check for any type of corrosion on the logic board and other parts. Then just replace the screen and assemble everything back together and that should do the trick.
このアンサーは役に立ちましたか?
All other functional working perfect and I did test different LCD but it is same problem. I even turn it on with no any other parts like camera or charge port. I never seen like this problem before.
このアンサーは役に立ちましたか?
Most likely grayscale (now knownas Color filters) is turned on
turn that off in Settings-General-Accessibility.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 158
1件のコメント
David さんによる
