メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2686回答 すべてを表示
When plugged in phone slightly vibrates but doesn’t power up
iPhone 6s vibrates slightly but not turning on have tried battery and screen on another iPhone both work fine could it be logic board or something else? It worked fine with smashed screen gone to change over screen but won’t turn back on can’t understand why when on main part of phone nothing was touched
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Either damaged screen connector on board or blown backlight filter.
Filter is extremely easy to blow up if the screen was connected / disconnected from the board while the battery is plugged in on the iPhone 6s.
Either of those will require a reputable repair shop that does micro soldering / board repairs to fix those problems. You may be able to find someone locally in your area that offers that kind of service.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Where would I be able to see where thats happened
さんによる
ok the battery is now def charging but screen is black still
さんによる
Shine a flashlight on the screen and see if you can see an image that is very dim meaning the backlight is gone on the phone.
You may need to replug the battery and look for the dim apple logo when turning it on.
さんによる
コメントを追加
回答を追加する
Jenna simpson さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 27
今までの合計 2,771
