メインコンテンツにスキップ
冷凍庫を含む冷蔵庫の修理と解体ガイド。
774の回答 すべて表示
Kenmore french-door refrigerator (model 2537034341B) ice cubes too big
Hi,
My Kenmore french-door refrigerator (model 2537034341B) has an ice maker built in to the main refrigerator cabinet, separate from the freezer. I have noticed that recently my ice dispenser stopped dispensing ice. I can hear the auger turning and just small pieces/crumbs of ice come out. After removing the ice container and manually operating the auger observed that the pickup barrel at the front end of the auger was not able to get ice cubes in it. Then I saw that this was because they were too big to fit in the openings on the barrel. I took a closer look at the cubes and it appears that the ice maker is overfilling the ice cube tray. I have read that some ice makers have the ability to adjust the cube tray fill time. Is there any way to adjust the water level on this ice maker? Maybe an option would be to reduce the water pressure to the ice maker?
I have also tried to “reset” the ice maker hoping it will recalibrate but I don’t have any results to report yet.
Update (11/26/2018)
I tried to reset the icemaker by disabling it from the fridge controller and then unplugged power from the fridge for 5 mins, and then turned the icemaker back on. This did not resolve the issue.
Icemaker parts reference diagram:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
PCラップトップ用バッテリー
An easy fix for a big power boost.
ショップを見る
PCラップトップ用バッテリー
ショップを見る
1回答
最も参考になった回答
The front cover of the icemaker will need to be removed (pulled off), to adjust the water fill.
To pull the icemaker out, remove the 2 screws on top of the icemaker mold and there should be one screw under it. The icemaker will now be free to pull out and turn, so the front cover can be removed.
The adjustment is only slight and if it still overfills, the water valve may be defective,
この回答は役に立ちましたか?
スコア 1
コメント:
Hi @mayer, thanks for your suggestion. I've taken this icemaker apart several times now trying to investigate this problem and I don't recognize the parts you're referring to. I've put a diagram of the icemaker parts in towards the bottom of the initial question. Could you please update your instructions based on that diagram?
Thanks!
による
コメントを追加
回答を追加する
LibertyChief さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 39
