メインコンテンツにスキップ
The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
60の回答 すべてを表示
Why am I not getting gas to my fuel pump?
Truck has new fuel pump which ran excellent until I blew a fuse on the tail lights. Replaced fuse then theft system came on, cleared codes on theft system. I can pour gas down fuel injection and truck will run on that gas. til it runs our. Just sits and cranks after that.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
@john2367 what was the issue that your son found on this?
by
コメントを追加
2件の回答
選択されたソリューション
Thanks but my son stopped by and found the problem. Wire to fuel had a bad spot inside the tank.
この回答は役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
hello magcitrate_41, I’m John it sounds like the vehicle went into anti-thief mode. one thing you could try is to disconnect the battery terminals both of them. Take the terminals and tap them together to completely drain and conductive energy from all the control modules. The ideal here is to reset the system completely. After reconnecting the battery put the key in the Ignition and turn to the on position. Let sit for a minute and start the vehicle.
Also you can try this link that will help you reset the PCM.
https://search.myway.com/search/video.jh...
この回答は役に立ちましたか?
スコア 1
コメント:
by any chance can you inform me what it was or what he did?
by
コメントを追加
回答を追加する
magcitrate_41 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 57
