How to replace logic board iMac 24 inch 2008
how to replace logic board imac 24 inch 2008
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@dandatu follow these instructions ==>>>Logic-Board-Removal.pdf
Here are a couple of things that will help besides the document
If you really need to replace the logic board look for the following boards
Apple part number 661-4428 2.4 GHz, Core 2 Duo
Apple part number 661-4430 2.8 GHz, Core 2 Duo
このアンサーは役に立ちましたか?
Thanks, that got the Logic board out for me… Only to discover that the Video card I ordered was for a 2009 model, not a 2008 model! Whoops! Found one for cheap.
このアンサーは役に立ちましたか?
I got stumped on this project- I can’t find a replacement video card for mine. I found the AMD card, but the heatsink assembly is shorter and won’t fit. Can’t find the nVidia card that will fit.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,387
1件のコメント
I found you a replacement logic board but I couldn't find a guide on how to replace the logic board, if that makes sense.
iMac Intel 24" EMC 2211 Logic Board
[deleted] さんによる
