メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
136回答 すべてを表示
Can I replace the power button with an alternative?
My Xbox power button stopped working altogether and I have to use the disc tray button to turn it on or unplug it to turn it off (which if I plug it back in it will shut off after a few minutes), and I'm sick of dealing with this. I want to replace the power button, but I haven't found anything actually helpful, just complex boards. Can I cut the wires and attach a power toggle switch to the wires, or will that just break it further?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi,
Have you checked the teardown of the Xbox (Xbox Disassembly).
The last two pictures give you a good idea of the cables of the power button (yellow ribbon).
If you want and are capable you could figure out which of these cables are connected to the power button, and replace it with almost any other button.
Enjoy, and be carefull
Kind Regards, Brenda
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Evan Thienes さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 75
