My MacBook Air is not recognizing the keyboard or trackpad
what could cause this issue? I have perviously replaced the SSD.
Your trackpad and/or the IPD cable needs replacing. Your system uses the trackpad as a junction for the keyboard with the trackpad signals and then the two signals travels to the logic board over the IPD cable.
Here’s the IFIXIT guide you’ll need to follow: MacBook Air 11" Late 2010トラックパッドの交換 and here’s the needed parts IPD Flex Cable and MacBook Air 11" (Late 2010) Trackpad
You should also see what your battery looks like using CoconutBattery
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 49
