Dual fuel tank issues
Switched from front tank to rear and the truck shut off immediately. Switched back to the front tank and the truck still won’t get fuel or start. Any ideas why?
It could be the switch is bad and the fuel pump for the rear is bad. It proabably both, when you flip the switch to the rear is shuts off due to a bad fuel pump and aint going to be able to pump fuel and when you flip the switch back it aint sending a current through to switch back to the front tank but it also could be a wiring problem
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,151
