メインコンテンツにスキップ
Repair guides and support for your Toshiba TV.
166回答 すべてを表示
Why is the screen on my Toshiba 32S3653 so dark?
Hi
My TV was working fine today then I came back and the screen was really dull. Could only just see it.
I've loaded some photos
Thanks for any assistance.
Darren
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hi,
Unfortunately not.
The picture is faint in the background, sometimes getting brighter but never bright.
さんによる
コメントを追加
2件の回答
最も参考になった回答
iFixitでの質問に画像を追加する方法 to post some pictures with your question. From what it reads like, this is a backlight issue. Most likely a bad power board but there is also a possibility of a bad main board or bad backlight strips. Let us see what it shows and eventually you will have to remove the back cover and take a look at the boards. Post some images of those as well.
Update (11/13/2018)
Since it is a Toshiba, service manuals are hard to come by. Toshiba is paranoid about their manuals and does not want anybody to fix their stuff. I attached the schematic for the PSU. Measure the 24V and 12V rails and see if those voltages are present.
17IPS62-r2.1
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks, they were in media manager and I assumed available. Thumbs up
さんによる
コメントを追加
Check in setting brightness, make reset all setting, when still dark, looks like LED invertor defekt...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I will check that tonight. That doesn’t look too expensive.
Cheers
さんによる
コメントを追加
回答を追加する
Darren Fletcher さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 3,604
