メインコンテンツにスキップ
Repair guides and support for your Toshiba TV.
192回答 すべてを表示
40volts to the back lights then slowly loses it
Hi I have the same problem, it seems to send 40volts to the back lights then slowly loses it, the power board does look like it's got hot around one capacitor cam this be fixed with out replacing a whole board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Michael Quarterman  that is a big depends. It is possible that this is strictly a capacitor issue. It is also possible that this is a failure of some other component that causes a capacitor to fail etc. First thing you need to do is to tell us the exact make and model of your TV. After that you do want to post some good pictures of your boards with your question. That way we can see what you see and make further recommendations.iFixitでの質問に画像を追加する方法
Right now it is most likely that this is an isolated power board issue. Toshiba is another one of those Silent Running Black Helicopter companies that is absolutely paranoid about providing any information to any DIY’er, so schematics etc. may be difficult to obtain
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Michael Quarterman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 32
