メインコンテンツにスキップ
A power supply is an electronic tool used to supply electrical power to some type of electric load.
11回答 すべてを表示
Power Supply only boots after days of sitting unplugged
Hello! I have a Cosair CX500M that is having issues booting a PC. The system will always turn on (HDD, GPU, fans, etc.) but nothing will initialize. When the system will boot successfully, the CPU fan immediately spins up faster than it would when my PSU is having this problem. If I allows the PSU to sit unplugged for a few days it will boot up 100% of the time and remain on for days without issue. If the system shuts off and attempts to power back on it will not work. I suspect that it only boots when the capacitors are fully discharged (or close to it) and otherwise the motherboard is not receiving the Power Good Signal.
My question is, how can I quickly drain the capacitors? I saw a guide here on IFixIt about building a capacitor discharge tool, but I’m not sure how to use it. I have tried grounding the PS_ON pin for awhile (just using a bent paper clip) and that didn’t help. Any ideas?
And no, I don’t want to replace the PSU. I’m just using it in a test system and don’t really care if I break something.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
edmurphy98  here is the guide for building a discharge tool コンデンサ放電ツールの組み立て and you discharge a capacitor by connecting the end of the tool to a different connector on the capacitor. Make sure that you do not make direct physical (could be a heart stopping experience) contact with the tool or the capacitor while you discharge it. Unplug your PSU before doing anything like that. After discharge use a multimeter to ensure that the capacitors are completely discharged
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
edmurphy98 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 522
