メインコンテンツにスキップ
A home coffee brewer, released in 2011, manufactured by Keurig. Repair for this device is similar to all other Keurig models.
34回答 すべてを表示
Leaking water into the cup along with the coffee
I use my Keurig B40 with K Cups and plastic refillables. Both have the same problem. Yesterday, I noticed that water was flowing into my coffee cup along with the coffee. This makes for a rather weak cup of coffee . I thought that there was a leak where the top needle punctures the K Cup. I removed the rubber seal aroung the needle. I cleaned the seal and the surface around it. There was a lot of old coffee around the needle.
I reassembled the seal and made a new cup of coffee. The same thing happened. When the brewing was complete, I removed the K Cup. The top was dry. I found the same thing with the plastic reusable. Water is bypassing somewhere, but the top is dry.
What should I do next?
I found the problem after taking the top cover off the Keurig B40. The hose to the water injector had pulled loose and thus most of the water was bypassing the K Cup. I put it back together and the problem is fixed for $0.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Remove the top cover. There are 2 screws at the front under the cover. Then check the hoses.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This problem happens eventually to 90% of Keurig (and other) machines when brewing reusable K-Cups like My K-Cup. There is an easy fix for this available on ebay for $4.95 that works like a charm. It’s a new part to add in the lid of your brewer in seconds without tools and is guaranteed to fix this problem instantly or your money back - including return postage.
Click this link:
https://www.ebay.com/itm/171557357690
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This is an old picture from 2015 when the price was $3.69.
さんによる
コメントを追加
回答を追加する
Brooks2 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 87
今までの合計 2,092
