メインコンテンツにスキップ
Released July 24, 2014, Amazon's Fire Phone is Amazon's first smartphone, designed to compete with iOS, Android, and Windows Phone devices.
39回答 すべてを表示
display broken, touchscreen works
Display broken but all touch r working
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
you need to give us some more information. It is most likely that you need to replace the entire display as the digitiser is glued to the LCD.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Possibilities of what your problem could be…
  1. You broke your phone’s glass, but the touch is still working.
  2. The phone is not showing anything on the display, but the digitizer works
  3. Something that is not on this list that needs more specification
Either way, you are looking at a screen replacement. I don’t advise replacing the LCD only because the glass and the LCD are fused together. (you'll be swearing until the swear jar is full)
Amazon Fire Phone Display Replacement
https://www.ebay.com/itm/OEM-Amazon-Fire...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
balajee abm さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 43
