メインコンテンツにスキップ
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
85回答 すべてを表示
Left Ear not working, works when I bend the wire a little
I stopped using this headset for a while, so I packed up the wires and put it back in it’s box the way it got shipped to me. I opened it up back in December of 2017 when I got a new PC. It worked fine for a long time, although the wire braid started to wrap around itself, causing the underwire to become exposed (not the actual wires under the entire thing, just the not braided point that has a matte color, it’s still covering the actual wires) and bent at a very steep angle. This was completely harmless to the audio quality for months. Eventually, sometime back in August, the left ear stopped working suddenly, and if I bent the wire in a certain position it would start working again, until the wire was touched again. I dealt with this for the longest time until suddenly it just stopped working no matter how much I bent it and what direction I bent it in. These knots happen all up and down the wire. I’ve been fine with this for a long time, and eventually I got used to it, but honestly its the most annoying thing. I paid 100 bucks for these headsets, and they had the best sound quality I had heard in a long time, and I desperately miss the amazing sound quality. I honestly don’t have the money to pay for these again. Any help is appreciated! Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
IF you want to keep it, you will need to repair the wire. IF it didn’t short out a component on the motherboard of the headset.
-Cut wire
-Bad ground
-Solder loose
Right to repair baby! start to repair it, tear it down … open it up.. what is the worst that can happen? it breaks? It’s already broken. Out of the wire harness, it is probably 1-2 wires cut. You could repair them by splicing a piece of wire into it, or redo the entire harness. You could find cheap headphones in goodwill to use the wire harness from them.
You will need a soldering iron .. solder..
or wire, wire crimps… you got the idea : )
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for this information, and thanks for answering. This sounds like much too effort and risk, because really any headphones is better than nothing, and breaking these doesn't seem like a good idea. Tbh I think I would rather just wait a bit for the next paycheck, and buy 'em again. I like to spend as little as possible, but for this case I would much rather spend money than put in all this effort. For some this would be a fun project, but it is definitely not for me, unless you can sell me on some other aspects of this, or give some other details, this is a hard pass for me.
さんによる
コメントを追加
回答を追加する
Alamir さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 26
今までの合計 3,818
