iPhone 6 plus touch unresponsive
i have a i phone 6 plus with a unresponsive touch i took it to a specialist and he replace the ic chip but after a day with it the touch goes unresponsive again.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Just take it back to the lab where the job was done, if they’re a reputable company they’ll stand behind their work and fix it or refund you the cost they charged you.
このアンサーは役に立ちましたか?
iPhone 6 plus series have common issues that only the IC`s replacement is not solution ever,There most me some needs micro jumper too.There M1 point be heated and dry soldering the pin so needs that tutorial may help you. This videos tutorial makes you help.So only changing without this jumper may cause problem after 15-20 days after the replacement of the Touch IC.
このアンサーは役に立ちましたか?
Please edit your post.
I think that is the same shop the OP took the phone to ><
Take it back to the repair center and have them watch this video.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 56
