メインコンテンツにスキップ
2018年7月に発売された15インチMacBook Proです。モデル番号はA1989です。15.4インチ LED-Backlightディスプレイ、True Toneテクノロジ、TouchIDと最大6 Core i9プロセッサを搭載しています。
40の回答 すべて表示
How to reset SMC on the 2018 MBP?
Instructions given on apple website at the link for T2 equipped devices are simply not working
https://support.apple.com/en-us/HT201295
The device simply boots up on attempting any of the 2 given combinations.
Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Can you explain what you are trying to reset. The more detail the better.
による
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
3回答
Press Shift + control + option button with power at the same time and release after 60 seconds altogether and continuously watch the light on the magsafe it will change color of led for a short duration of time indicates SMC reset has been successfully done
この回答は役に立ちましたか?
スコア 0
コメント:
Hello, and thank you for the kind reply.
This may work on older models, not the new 2018 with the T2 chip.
Also, And these models do not have a MagSafe.
による
Is your battery detachable or not or with touch ID
による
Systems with a T2 chip are very different than the older systems. Some settings are just not resettable. Depending on what the issue is we may need to use a different way.
による
Yes, I realise that systems with T2 are different, and therefore requiring a different procedure for the reset. I followed the instructions on apple page for systems with T2, that Aaron also posted. but this is not working. the system simply boots up 2-3 seconds when attempting any of the 2 alternatives. That does not sound right
による
SMS - What are you trying to re-set?
による
表示する 5 他のコメントを
コメントを追加
Here’s a guide on how to reset the SMC and the PRAM on your MBP. Hopefully it will work for you. If not, maybe @danj can assist you better if you provide more detail.
MacBook Pro Touch Bar 2018のSMC, PRAMとNVRAMのリセット方法
この回答は役に立ちましたか?
スコア 0
コメント:
Thank you Aaron. Yes, I attempted that, but the systems always boots up during the procedure, actually within 2-3 seconds of attempting any of the 2 alternatives
による
Okay, hopefully Dan will be able to help you further. Sorry about that!
による
コメントを追加
Shift+control+option with power button
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SMS さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 53
今までの合計 472
