Lens error, restart the camera
I am getting this message when I press the on button. The lens is not retracting in.
Lens error, Restart the camera.
Can you please help?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Pinky Kasotia , this is usually caused by sand or grit interfering with the lens extension mechanism, or the camera's been dropped with the lens extended. It is also possible that the camera has been powered on, but the lens had been blocked preventing its extension....okay there are plenty of causes. Check on here for a more concise solution. Good luck
このアンサーは役に立ちましたか?
lens do not get back when on/off button is pressed.
このアンサーは役に立ちましたか?
same answer as above :-)
can you help for restart the camera
このアンサーは役に立ちましたか?
Camera lens does not move when switch.
過去 24時間: 5
過去 7 日: 11
過去 30 日: 24
今までの合計 5,805
