メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
360回答 すべてを表示
Sanyo dp39d14 turns on, backlight on, sound is heard, no picture
I have unplugged and plugged back in the TV. The tv will turn on , sound from playstation will come through and you can see the backlight of the TV is on. There is no picture though.
I have unplugged the playstation from the TV and unplugged the TV and plugged back in still the same results
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
@kristian93
try all the different video sources as well. If that does not make a difference then you most likely have an issue with the main board. Remove the back of your TV and take a look at all the boards and check for obvious damage. Reseat all the cables and try again. Post some images of your boards with your question so that we can see what you see. iFixitでの質問に画像を追加する方法 This series had issues with the EEPROM on the main board ( repalcments need to be soldered to the board etc.)
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
I do no see any damage to the TV.
What do you mean by reset all cables
さんによる
The individual cables that connect the board to the rest of the components.
さんによる
I have unplugged each and plugged back in, the back light is on, still no picture though. I have tried to high input on my remote and straight from the TV. The screen is just a dark blue light
さんによる
Okay sounds like a board issue, possibly the scaler or the EEPROM. I do not have any schematics for this board and they seem to be scarce if even available. Consider trying a new board or replace the EEPROM if you know how to solder. The EEPROM could be a possibility. Do you have one more board behind the panel bracket?
さんによる
No the one in the photos is the only panel board
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
K Williams さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 831
