メインコンテンツにスキップ
11インチディスプレイのMacBook Airモデル
930回答 すべてを表示
Green light on, battery symbol says 'charging' but battery is draining
I replaced the battery which was really shot. New battery showed good charge and charged to 100% one time. After that, battery is discharging but green light shows on charger connecter and battery icon in menu bar shows ‘charging’. SMC and PRAM resets seem to have no effect.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Please see my 'answer' below for a photo related to this comment.
So some time after posting my problem with the 2011 Macbook Air, above, I was giving it a long last look before tossing it. Next to the battery connector is a package about 3/4 inch square. On one side it attaches to the logic board by two stout solder points. Looking very closely I discovered cracks across both of these connectors. Wiggling this package would intermittently cause the battery to actually begin charging. So — solved. A touch with the soldering iron and a tiny bit of additional solder and the Macbook is back in business.
I would add, this computer has been severely abused. Dropped, hurled, knocked around. The case is so badly bent you can practically hold it edge-on and see daylight out the other side. My wife thinks I should send it to Apple as a testimony to its toughness. No idea how much longer it may last, but for now it is repaired and working as it should. At least as regards charging the battery.
さんによる
コメントを追加
5件の回答
ベストアンサー
This photo shows the IC package which had the cracked solder joints, that is the two showing at the top side in this photo.. Please see my ‘comment’ above to my original question for more detail.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Sounds like board repair required. Most likely charging ic requires attention…
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
'Charging IC' -- is that something I could change out or repair without nutsy hassle?
さんによる
lkrndu, did you find a solution? I have the same problem.
さんによる
Erin Campbell, yes I found a solution. I'm late for the train -- maybe you've moved on by now but here is what I found out. Please see my answer with picture posted below.
さんによる
コメントを追加
Maybe your computer doesn’t recognize the new battery but your cable does…. this is pretty strange…….
my my answer is what I assume….. you could get apple support or here https://support.apple.com/mac/macbook-ai...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Max Li, please see my comment to my original question, above. I did resolve this matter, as you will read. There were two broken solder connections from what I assume is a power management IC on the logic board. Resoldered, fixed.
さんによる
Ok thanks for letting me know
さんによる
コメントを追加
(See my 'answer' to my own question, below, for the picture that relates to this explanation.) Next to the battery connector is a package about 3/4 inch square. On one side it attaches to the logic board by two stout solder points. Looking very closely I discovered cracks across both of these connectors. Wiggling this package would intermittently cause the battery to actually begin charging. So — solved. A touch with the soldering iron and a tiny bit of additional solder and the Macbook is back in business.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lkrndu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 93
