The true amount of maximum RAM?
I understand that in the 2012 unibody models that you can upgrade the RAM to 16 GB, even though Apple says that the max RAM is 8 GB. Is this the case with the 2011 unibody MBPs?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 95
6 件のコメント
You know better than to not be specific as to exactly which machine.
mayer さんによる
@mayer How was I not specific? The machine I am referring to is the device I listed.
[deleted] さんによる
this year's MBPs? 2018? Is English your second language?
mayer さんによる
Fine, that may have been a bit vague. However, I got the answer I needed.
[deleted] さんによる
I really didn't understand the question. You can get offended or you can work on your composition. This is not the first time you have lacked clarity. If you intend to go to college, you will need to work on this. The Cardioversion didn't work. next procedure is called an ablation. I'll be scarce for another week.
mayer さんによる
1以上のコメントを表示
