I can't see the HDD in the enclosure
I everyone,
I just upgrade my mac book pro with a SSD and the hard drive enclosure 9.5.
I don't have any problem to see the main disk (SSD) but it's impossible to see the 500GB hdd in the enclosure. I follow the guide point by point and everything is connected I just can't see it in disk utility.
Thanks in advance for any help.
この質問は役に立ちましたか?
4 件のコメント
So my old hard drive is a 500GB momentus XT (hybrid). I put the new one in the classic hard drive place and the 500GB in the enclosure. I did have any problem to instal OsX on it, but after that I can't see my 500GB in disk utility...
I will try a other HDD in the enclosure if that doesn't work I'will try to see it with a windows intal.
I will keep you posted about my try.
emericpinon さんによる
Let us know what happens when you use another hard drive in the enclosure and try it on your windows machine. It definitely sounds like some problem with the enclosure or hard drive.
Are you using an external power supply for the hard drive? I know you have to supply some kind of power to SATA drives in order to be able to use them externally. They wont work if you just plug them into the USB.
Xnriqu さんによる
problem solve ! so I change a first time my HDD hybrid (in the enclosure) with a hold 160Go (didn't work) then by a recent 640GO 7200tr and that work ! I believe there is a power limit for the enclosure.
emericpinon さんによる
Glad I could help solve your problem.
mayer さんによる
