メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
78回答 すべてを表示
How can I fix my flashing screen (TI-84+CE)
My calculator seems to have decided to no longer likes me, and is having startup issues.
It is stuck on a flickering white screen. I can’t turn it off. It doesn’t seem to be turning off on its own. I’d prefer to not have to completely wait for it to drain considering that I just finished charging it yesterday. The calculator does not seem to fully load at all and does not appear in the TI Connect CE program when plugged in to the computer. This is my personal calculator and I’d really like to have it fully working again, and if possible, salvage the programs I have on it. Is there anything I can do, short of buying a new calculator? Or is there a factory reset feature available anywhere I can use?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Try doing the recovery techniques listed on the guide I have linked to below. Hopefully one of those techniques will work for you.
TI-84 Plus CE Recovery Techniques.
このアンサーは役に立ちましたか?
スコア 7
4 件のコメント:
@thelastmill This problem was solved compliments to your wonderful guide, thank you!
さんによる
Performed a hard reset on the calculator by clearing the ram using the button on the back and just redownloaded my programs. The slideshow above is also extremely helpful. Thanks!
さんによる
@ahvey Glad it was helpful! Happy fixing!
さんによる
I'm glad it was useful! :D
さんによる
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 53
過去 7 日: 263
過去 30 日: 2,079
今までの合計 19,981
