メインコンテンツにスキップ
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56回答 すべてを表示
Why does the ABS & Emergency brake light stay on all the time?
My truck only has 25,000 miles on a 2008 Ford F150 1/2 ton. Lately the ABS & Emergency light comes on 5 minutes after I drive off and stays on as I drive. The emergency brake is not on, except when I park, then release when I drive off.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You need to stop at an auto parts store while the light is on and have them scan it to see what codes are in it. To guess I would say the wheel speed sensors on your front wheels are dirty. Start the car let it idle for five minutes if light dosnt come on till you are driving it's probably the wheel speed sensors. A can of brake cleaner and spray the sensors off. Then again if you were offroading before the light came on maybe just look under your truck to see if some wires got pulled loose. Also when the light comes on put the ebrake on and off if the light goes off the ebrake switch might be a little loose.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
gamgam41moore さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 1,176
