メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
The Canon EOS Rebel T5, also known as the EOS 1200D, is an 18MP DSLR camera released in February 2014.
29の回答 すべてを表示
Canon EOS Rebel T5 - External flash not recognized
Hi,
I have a Canon EOS Rebel T5, and when I connect a generic (compatible) external flash, it trigger itself continuosly and in the menu it shows Accessory not recognized.
P.S.: It worked fine for some time, but one day it started doing this. The flash came within the bundle.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Flash is probably not compatible with your camera, I guess. That's why serious flash guns have usb ports so you can update the firmware of the device. If your flash has usb then try to update it. Else, try manual settings. It should at least fire.
この回答は役に立ちましたか?
スコア 0
コメント:
Please, read the question, i know there are some incompatible flashes, but i've had used that same flash for about 6 months, and then, suddenly it started to self-trigger the moment I connect it.
さんによる
コメントを追加
回答を追加する
Jesus Lau さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 146
