Problem with pression point/spot blue doing screen replacement.
Am i the only one or are you guys encoutering some problems with iPhone 7 LCD also?
Now i’m removing the low retaining bracket to be able to fit in my LCD. Note : This is the OEM quality here in Montreal. (a friend told me that he’s installing the flex cable under the metal plac,but i preffer without the bracket then leaving my flex cable hanging out unfixed).
So,what do you guys do when something like that happens?
Thank you!
5 件のコメント
I'm not seeing anything wrong with the screen? I'm on a crappy laptop so might be the reason but still. Is anything wrong, like you can't tap in that spot?
Dave Feil さんによる
Without the bracket he wont feet in and that's a light spot also. Not normal at all.
DouglasVinicio さんによる
Like subtly brighter or..?
Dave Feil さんによる
In a photo it could looks like its subtly,but trust me it is not.
The second photo you can see that the frame aren't touching the body. It is easy to see.
