Why won't my Samsung M2020W laser printer operate wirelessly?
My Samsung M2020W printer used to work wireless but will not do so now.
It might be missing drivers or an accidental removal of drivers. What have changed since it was ok? have you installed some program? have you uninstalled something? have you changed some network settings (I am talking about windows platform)
このアンサーは役に立ちましたか?
have you changed your router?? if so uninstall and reinstall drivers and rediscover the printer.
Set a fixed IP on the router in IP address reservation page of your router's
admin page
Have you unchecked Network adapter settings?? that is a good point to start.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 296
Does your computer see it? What kind of operating system are you running? Will the printer work with a wired connection?
mayer さんによる
Using win 10. Works well with a wired connection
Scotty Day さんによる
Hi,
did you get your problem fixed?
I'm having the same problem. Suddenly the printer went offline.
Checking the known IP via browser wasn't successful either.
Connecting to USB showed the printer in easy wireless setup.
However the settings applied there didn't solve my problem.
As if the WiFi connection of the printer is dead!!
Any suggestions?
Benjamin
ben さんによる
