Why does my controller not charge?
My controller will not charge. Sometimes if you get it just right it will charge for about 4 seconds and then turn back off. What should I do?
It may just be a battery issue. You can replace the battery with the part below. I also provided a guide on how to replace the battery.
DualShock 4 (JDM-030 and Earlier) Controller Battery
Here’s how you can replace your charge port, if necescery. Choose the right charge port for your model controller
製品
$8.99
製品
$5.99
製品
$6.99
ガイド
難易度:
簡単
10 - 15 minutes
ガイド
難易度:
中レベル
25 - 40 minutes
このアンサーは役に立ちましたか?
Hi @ajcooke01 ,
Not disagreeing with you but the OP states "Sometimes if you get it just right it will charge for about 4 seconds". I'm wondering if the "....get it just right..." relates to the USB cable connection and perhaps it may be a loose or damaged port.
Your thoughts? ;-)
I haven't had time to get around to fixing it but I am going to this weekend. That could be a possibility as well. If you have a link to a guide that might help me with that it would be much appreciated!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 89
