メインコンテンツにスキップ
Released December 2014, the ZTE Z667 is a T-Mobile prepaid 3.5 inch android smartphone that features 4G LTE and a full keyboard.
2回答 すべてを表示
Looking to get contacts off my ZTE with screen that won't navigate.
My ZTE Z795G (not Z667T, I couldn’t find Z795G on the list) touchscreen stopped working. I have a lot of contacts on there, can I still get them? Prior to switching service to a new phone, my ZTE would ring and vibrate and the screen would turn on and change - but it is unresponsive to me touching it. Thoughts? Thanks.
(Some of my contacts went to my new phone, but most of my recent contacts did not. I’m afraid that they are stored on the internal memory of the ZTE phone. Everything else I’ve seen online says that I could get the contacts if I could navigate the screen, but that is not an option.) Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I will try this later and let you know if it worked. So, all I have to do is put the SIM card in my new phone?
さんによる
It might be a different sized sim or sim slot in the other phone but you can buy a sim adapter or just be careful that a smaller sim doesnt get stuck in the slot, which is what i do. There are 3 different sim sizes normal sim, micro sim, and nano sim. They are all the same they just have different amounts of plastic on them.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
It may or may not be saved to your sim card. You can check this by just inserting the sim into an other phone. If your contacts show up then your good to go! I also have Tmobile, and from my experience the default setting on Tmobile prepaids they should be automatically backed up. I hope this helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rob Jach さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 101
