(Satellite Radius P55W-B5224) CPU fan not running or recognized.
Turn the computer on (normal boot), login, wait a couple of minutes, and the computer spontaneously shuts off. CPU thermal protection at work, right? Right.
Reboot the computer into safe mode with networking. Same thing happens as above, only it takes ~10 minutes for the computer to shut off.
Take off the base and push the fan with my finger. It moves easily. Just to be sure, blow some air through the fan to the rear vents. Almost no dust comes out and the fan spins freely so it’s not seized.
Unplug the fan from the motherboard and rig 5V power through it (the fan is rated for 5V .4A) and the fan spins up immediately with good flow. So the fan isn’t the problem.
With the base still off, rig a small desktop fan to blow directly on the CPU, then turn on the laptop. It runs indefinitely as long as I don’t stress the CPU. After ~5 minutes I get an error on screen saying that there’s a thermal problem and I should return the laptop to Toshiba for service.
Install and run SpeedFan. It doesn’t even see the fan connected to the system.
Next steps?
この質問は役に立ちましたか?
