メインコンテンツにスキップ
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
22回答 すべてを表示
Why can I no longer set the alarm time?
At first, the clock numbers were scrolling fast when I entered the room, beeping when it got to the set alarm time, and continued on. My son unplugged the clock and it again scrolled fast. Unplugged and plugged in again, and this time, the time appeared, but I can no longer set the alarm time.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @stan_the_man7 ,
Try the following:
Switch off and disconnect the AC power from the clock.
Remove the backup battery from the clock. Take note of the orientation of the battery as you remove it. That way you’ll reinsert it the correct way. ;-) Here’s a link to the user manual that shows how to do it.
Press and hold the Enter/Time Set button for about 10 seconds and then release. (this will discharge any residual power from the clock and release any “corrupted data settings” that are being “held”, that may have been caused by power fluctuations or surges etc.)
Reinstall the backup battery
Reconnect the AC power and test if you can now set it OK
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Brenda Eash さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 152
