Does this model often have bad capacitor problems
I have heard that this particular model has bad caps. Is this the main reason why the computer shuts down repeatedly?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
See if your serial number (located on the bottom of your stand falls within these ranges:
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx – W8522xxxxxx
QP435xxxxxx – QP522xxxxxx
CK435xxxxxx – CK522xxxxxx
YD435xxxxxx – YD522xxxxxx
このアンサーは役に立ちましたか?
My iMac has a serial that begins with W8523 and I just discovered leaking capacitors on it, causing the computer to behave very erratically and only start up occasionally, so the problem seems to go outside the stated range.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,249
