メインコンテンツにスキップ
モデル番号A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 プロセッサ
330回答 すべてを表示
Half of screen black after internal SSD installation.
Half of my screen is black after installing a 1TB SanDisk SSD. The back lights are on, so it’s not that. I’ve heard there are many other people where this problem exists.
Many different theories and ideas…. ie. fans, erase Fusion Drive (which I did erase)
Any suggestions?
BTW, it reverted to OSX 10.6.6 - I WAS on 10.13.6 could that be an issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sadly, its none of these ideas!
In the process of opening your system you damaged the display assembly. What happened and you’re not the first! Is using the wrong tools as well as the technique to remove the display. Most of the time people dig too far with the tools and use a tool which cuts into the fine wires that make up the grid (X-Y) wires that drive the LCD which are along the edge of the displays glass surface. The other is prying the display up which can stress it. If you release the adhesive correctly the picks and cards is all you need to lift it up enough to then with a light touch lift with your hands far enough up to disconnect the cables. I could even use my pinky fingers to do this just to put into scale the amount of force needed here when its done correctly.
Review this IFIXIT guide: iMac Intel 27インチ EMC 2546 ディスプレイ交換 and you need to use the correct tools:
And you do need to replace the adhesive strips
  • [リンクされた製品が存在しない、もしくは無効: IF174-005-2] - I would get two sets.
At this point you’ll need to buy a new display assembly here’s one source: iMac 27" LCD Display Panel & Front Glass Assembly (12/13)
Plastic Cardsの画像
製品
Plastic Cards
$2.99
iFixit Opening Picks (Set of 6)の画像
製品
iMac Opening Wheelの画像
製品
iMac Opening Wheel
$7.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
No,
I used these techniques to open it. Same tools.
Anybody else have an answer?
さんによる
Sorry guy bad display no matter what.
You stated the backlight is working so then it's the driver logic which is part of the screen as well. More often it's the damage to the display during removal, if your driver was dyeing you should have seen some artifacts on the screen before you took the system apart. But then again you could have just been unlucky the extra pressure on the screen taking it off caused it to fail.
さんによる
コメントを追加
回答を追加する
Bryan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 50
