Can I put my Wi-Fi diversity antenna from a 6s in a 6s plus
Are they compatible ? If i take the Wi-Fi diversity antenna from my iphone 6s and put it into a 6s plus will it work?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
No, sorry. The antenna is not interchangeable and therefore is not backwards or forewords compatible. The connector is a little bit different on the 6S Plus.
However, if you do wish to buy a new antenna for your 6S or 6S Plus you can buy it here from iFixit at the links below.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 47
