メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
J5250 - C5250 - R5250 Removing After Water Damage?
Using a title that will get as many people from online to see it if they have the same problem and or an answer.
Customer spilled a cup of coffee behind the computer and it spilled inside through the air vents and onto the logic board BADLY! But 99% and some heat allowed a good ol’ cleaning. Anyways, it gets power, charges the battery, changes color at least but will not boot up, whatsoever. Tried no battery, only the battery and disconnecting everything, the usual steps before I ask for help.
On my PP3V42_G3H there is a thing on the board named J5250 with a Resistor ( I think) named R5250 and a capacitor next to it named C5250. Both are highly corroded, but I am unable to determine online what should be done with it. Or whether I should remove it or not.
Any suggestions?
I’ll include a picture of the schematics, maybe anybody smart can provide a good answer, should I remove the capacitor? Would this fix my problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@noah_smith “Both are highly corroded, but I am unable to determine online what should be done with it. Or whether I should remove it or not. Yes, if they are corroded they most likely have failed. Clean your board of all corrosion with some high grade isopropyl alcohol. then repalce the components as well as check the rest of the traces and components.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Just making sure they weren't something not worth replacing. I've already cleaned it A TON, but I'll once over it again. Do you know what J5250 does?
さんによる
J5250 is a connector
さんによる
Ok, thank you!
さんによる
コメントを追加
回答を追加する
Noah Smith さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 152
