メインコンテンツにスキップ
Nintendo DSiは任天堂 DSラインの第3番目となるモデルです。2008年後期に日本で発売されました。
263回答 すべてを表示
White Screen "?MENU" With r4 Card
I’ve been trying to get my r4 card to work for days now, and I’m getting a bit at a whits end. All it shows when I open up the r4 game is a white screen with a red SD card with “menu” written in it.
It’s a completely new r4 SDHC 2018 GOLD PRO. It’s a completely new SD micro card. I’ve tried changing the format, getting _DS_MENU.DAT files, getting patched ROMS and all that, and absolutely nothing has worked.
Is it because it’s a DSi? It was supposed to be supported by the r4, but the more I look around the more I can see many saying solutions will only work with DS lite.
Is there anything I can do???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
I Have the same problem i was about to try a naruto game that i tought was interesting and then boom it turned into white screen with menu? somethin my r4 card is a 3DS upgrade SDHC Dual core card and yes i know iam 4 years late
さんによる
@いペッパピッグは暑 thats a timebomb :(
さんによる
thats a timebomb :(
さんによる
Which R4 are you using? is the micro sd the right sized capacity, Because that might be the problem, like a 64 gb micro sd wouldnt work, i use 8gb micro sd with a r4 HDSC 2021
さんによる
コメントを追加
6件の回答
ベストアンサー
Thats an error that shows when you have not installed the correct kernel, for the r4 gold pro, the root of your micro sd card, should look like below,
moonmemo
moonshl2
R4iMenu
R4i.dat
We currently have r4i Gold on sale for $27 & Free shipping.
http://www.r4cardstore.com/R4-Gold-Pro
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I have those exact files and folders in my SD card but It still doesnt work. I keep getting the ?MENU error picture...
さんによる
This worked perfectly. I had to remove them from the folder they were currently in by cut&paste. If it still doesn't work for others then it may be that it's not formatted in fat32 and is larger than 2BG.
さんによる
i have a 64GB card, is it a problem??? I formatted it to fat32 btw
さんによる
コメントを追加
It sounds like you may have not set the r4 up correctly, here is a video on how to do it. hope it helps. https://www.youtube.com/watch?v=CWxmNJgl...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
That did get me further this time thank you. However now I'm just stuck on a loadingscreen where it says with red text that the card is fake and I should return to retailer? But I bought it fom a site recommended by others. Do I really need to get a new card?
さんによる
I had this problem too, you just need to make sure you have the right Kernel for your R4
さんによる
コメントを追加
The R4s are a bit touch and go with DSi units, I had one work for two systems, but not work for three others, all causing the same issue. You can try another card, or if it’s easier, another device. I believe it’s got to do with the last few system updates that were pushed out for them before they were left for the 3DS.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
But I have a 482 in one ds cartridge witch isn't a r4 card but how do I get the ds menu day back on that too
さんによる
コメントを追加
Welp do u have a r4.dat file in the sd?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No how do I get rid .dat
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What about kennel for Sunny Flash ds card?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have 2 different Sunny Flash Cards i can send you the .dat file if you want.
You need this key: f2CZZyxiq6Y26infrY6CZVjc7hjr1OgdmNHz3oV4ev0
mega(d0t)nz/file/rwVTwayZ
さんによる
コメントを追加
回答を追加する
Signe Engberg さん、ありがとうございました!
統計データ:
過去 24時間: 26
過去 7 日: 161
過去 30 日: 678
今までの合計 57,699
