メインコンテンツにスキップ
RCA Android tablet, identified by model number RCA RCT6303W87.
37回答 すべてを表示
My tablet froze and now it's not working anymore.
I've had my tablet for about two years now and all of a sudden yesterday ( Sunday, Sept. 30 ) my screen was froze so, I turned it off and it's not turning back on and or charging. The blue charge light isn't working either. I don't know what to do!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Try and plugging it into a computer and see if the computer recognizes a device being plugged in even momentarily, and let me know if you get some recognition.
Then try this. Although this will clear any pictures/games you have on the tablet
Hold Power Button and Volume UP button, a menu should pop up, using the volume keys scroll down to factory reset and hold the on/off button for a few seconds until it resets. If a battery symbol pops up, attempt to do the same with it plugged in to a computer or however you usually charge it.
If that gets you no where, I’m going to point towards the battery needing to be replaced, either it’s not holding a charge . Which after a couple years could be a strong possibility. Doing a quick search ifixit does have a couple guides on how to do this, but I couldn’t find the battery, other then conducting a google search and they range from $10-40 depending on what direction you want to take. My recommendation is don’t use ebay for buying parts, but that is a personal preference.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks so much!
さんによる
コメントを追加
回答を追加する
chassity laraye さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 153
