メインコンテンツにスキップ
第三世代の Surface Pro タブレットは、2014年6月20日にリリース。
123回答 すべてを表示
New LCD not working?
I have a Surface Pro 3 that had a shattered display. I replace the LCD assembly but it doesn't light up. I know the display, cable and shim/bridge are good because they work in another Pro 3. The display driver is the same as the one in the working Pro 3 and the unit is detecting the LCD because it shows in "Display Settings" when I plug into an HDMI monitor. IOW, it shows two monitors and the digitizer is working. Is there anything else I can try?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Try shining a torch at an angle close to the screen to check if you can detect an image at all when the laptop is turned on. It will be very faint so perhaps try it in a darkened room as it might be easier to see if anything is there.
If you can see an image you've got a backlight problem. Since you say that the new screen and screen cable are OK it must be back on the motherboard.
I don't know how it works in your laptop but on a lot there is a magnet in the lid, below the screen that operates a magnetic switch in the case to turn off the backlight when the lid is closed.
On some, newer Asus models for one, the switch is incorporated on the same board that holds the Power button. It sends a signal to the BIOS to turn the backlight power on and off when the lid is opened/closed.
Not saying that this is the same in your laptop but check for any other cables connected to the motherboard around the Power button area perhaps which may be loose etc
I assume that the GPU still works because you say “…the unit is detecting the LCD because it shows in "Display Settings" when I plug into an HDMI monitor. “ and you’re getting a display on the external monitor OK. Is this correct?
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
It is a backlight problem because the image is there when shinning a light on the screen. But there is no lid to close on a Surface Pro 3.
さんによる
Hi,
You may wish to contact @botenredwolf and ask if he has an answer as he was working on a similar problem
No LCD Backlight after repair.
Worth a shot ;-)
さんによる
コメントを追加
回答を追加する
Lew Murray さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 377
