メインコンテンツにスキップ
Retina MacBook 2016からアップデートされたバージョンです。モデル番号はA1534(EMC3099)です。Turbo Boost使用時最大3.6GHzの最大1.4GHz Core i7の高速Kaby Lakeプロセッサ、最大50%高速のSSDを搭載し、最大2倍のメモリをサポートしています。
81回答 すべてを表示
Is deleted BootCamp partition recovery become possible macOS Sierra?
I have accidentally deleted bootcamp partition on my Mac computer using disk utility because windows 8 has been damaged or corrupted while I try to resetting it. Note that I wasn't using bootcamp assistant to install windows 8. I managed to make my drive into a single partition but when I press alt/option on boot, I still can see the windows boot option and the data stored in it. How to repair my Mac hard drive so the windows boot option disappear?
Please tell me any solution on how to restore the BootCamp partition data back to my Mac hard drive and regain access to it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
You can take the help of a Mac data recovery software that provides deleted or lost BootCamp partition recovery features. Also, avoid using the Mac machine to make sure that no other files gets over-written on that Mac hard drive.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Sorry to say its not recoverable ;-{
When you deleted FAT32/exFAT partition and make it part of your GUID partition that did you in. A BootCamp install is a bit different than a raw Windows install which is what you did here. A BootCamp install creates a special folder to hold Windows environment in a VM space. A raw install is when you treat the Mac system as if it where a Dell/HP laptop but you made an isolated partition to run Windows vs MacOS.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
James Rough さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 861
