メインコンテンツにスキップ
GoPro Hero5 Blackは、2016年10月に発売、HD耐水性アクションカメラが搭載されています。4K解像度のビデオカメラにはボイスコントロール、タッチスクリーンディスプレイ、WiFi対応機能です。
LCD Screen not working
Good Day,
My GoPro hero 5 is working but not the screen, the screen has no power but it still response when you tap the screen
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
5 件のコメント
Me too. my camera's screen just stopped working and GoPro told me to send the receipt and I would get a new camera, but when I sent the receipt a different GoPro person told me I would only get 20 per cent off a new camera. I read that they were replacing all cameras with this default because it was a defect. Has anyone else experienced different messages from GoPro like this?
さんによる
Yes, I have experienced the same problem
さんによる
Yes I have the same problem with mine.
さんによる
There's a cable between the battery and micro sd card slot and that cable you have probabbly cut or something while accedantly putting the sd in the wrong place.
さんによる
LCD is not working of my GoPro black5
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi,
I assume that you cannot view the menus on the screen either
It may be either a loose connection to the LCD screen, that the LCD screen is faulty and needs to be replaced or worst case that there is a fault on the motherboard.
Try shining a torch at an angle close to the LCD screen to check if you can detect an image at all when using the camera. It will be very faint so try it in a darkened room if possible.
If you can detect an image it means that there is a backlight problem with the screen. Either there is no power being supplied from the motherboard to the backlight circuit in the LCD screen or the backlight circuit in the screen is faulty and the screen will have to be replaced as it cannot be repaired. Hopefully it is not a motherboard problem in supplying backlight power to the screen.
If you cannot detect an image (or even if you can) then unfortunately without a schematic, the only way to determine if it is a problem with the screen or the motherboard is to replace one or the other. Again hopefully it is not a motherboard problem.
Here’s a link to a video that shows how to replace the LCD screen + digitizer in the camera. This will also help you to check if the LCD video flex cable connection is OK.
Here’s a link to the GoPro Hero5 Black guides which may also help if the video isn’t clear enough at some points. Unfortunately there is no ifixit guide showing the LCD screen removal.
Here’s a link to a replacement GoPro Hero5 Black Rear LCD and Digitizer part from ifixit.
Here’s a link to a replacement GoPro Hero5 Black Motherboard part from ifixit just to give a comparison of the cost difference between the two parts.
You may find the parts cheaper elsewhere. Just search online.
Hopefully this is of some help.
This part is the motherboard for the GoPro Hero5 Black action camera.の画像
製品
$24.99
Replace a rear LCD display and touch screen compatible with a Black Edition GoPro Hero5 camera. Includes the Rear Glass Digitizer Panel and Flex Cables.の画像
製品
$69.99
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
So my camera's screen just stopped working and GoPro told me to send the receipt and I would get a new camera, but when I sent the receipt a different GoPro person told me I would only get 20 per cent off a new camera. I read that they were replacing all cameras with this default because it was a defect. Has anyone else experienced different messages from GoPro like this?
さんによる
The LCD screen is "lit up" for me but no image would this be a ribbon cable or something worse?
さんによる
@basicquestion
Take some pictures with the camera and then check if they're OK when downloading them from the SD card plugged into a card reader connected to a computer.
If the images are OK then it could be faulty LCD screen, a LCD screen cable/cable connection problem i.e. loose video cable, backlight power cable OK or a problem with the motherboard - LCD screen video circuit.
If the images are black then it's the motherboard.
I realize that you cannot "see" what pictures you are taking but the camera may still be mostly working OK if the downloaded pictures are OK
さんによる
コメントを追加
I fix mine take apart clean put back together it works
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
mr_gemini_31 さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 49
過去 30 日: 201
今までの合計 34,372
