メインコンテンツにスキップ
Mac Proとして知られるデスクトップMacシリーズの2013年版新モデルです。
117回答 すべてを表示
Extremely loud beeping on startup
I was going thru my tech teacher’s back room today and I came across a 2014 Mac Pro. I plugged it in hoping I would have found a hidden gem, but with my luck I got no dice.
As soon as I pressed the power button, there were 5 extremely loud beeps at least 1 second apart that almost made me jump. I unplugged it immediately, and tried again. 5 beeps. I tried the SMC, PRAM and NVRAM resets which all were to no avail.
TL;DR: 5 extremely loud beeps on startup each at least 1 second apart. Tried all the resets. Help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Here’s another reference: Macintosh Beep Codes
See if you can recover the EFI and SMC firmware using these:
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
@danj I cannot boot up the machine is therefore I can’t try those two things you mentioned. Replacing the CPU is just simply too expensive, so I think this machine is a brick. Thanks for your helpful input!
さんによる
It still might be possible!There is a special tool you can use to access the service connector on the base to recover the firmware. I'll need to find it when I go home for lunch.
さんによる
@ajcooke01 - Here's the info MattCard You'll need to ask for his beta card for the Mac Pro
さんによる
@danj I think I am going to just call it done. There is water damage to the Logic Board that I just discovered now that is beyond repair. I think I’ll gut it and use it as a ruler holder ;)
さんによる
Gee! Such a waste ;-{ Even if you got the four core Xeon logic board it's a great system! That's what I use for photo editing.
さんによる
1以上のコメントを表示
コメントを追加
最も参考になった回答
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
From what I could find digging through i fix it
MacBook 5 Beep Sound not booting up..
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Yep, CPU board may need to be replaced.
さんによる
@ambientprotect Thank you for your imput! I upvoted your answer to be fair too.
さんによる
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,674
