メインコンテンツにスキップ
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53回答 すべてを表示
How do I change the head gasket on my 2002 Mazda 626?
Oil is leaking from the head down onto the exhaust manifold. Is this the head or valve cover gasket ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
You could steam clean your engine and take a look after a drive to see where is comes from. My first guess would be that it is the valve cover gasket, since most of the time a head blown head gaskets manifest itself different. Not saying that it isn't, but most of the time you get misfires, loss of coolant and lots of different colored smoke with a bad head gasket. It is also a lot cheaper and easier to replace a valve cover gasket. So, clean it and take a look at it after a drive to determine where it comes from. Good Luck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Larry さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,400
