メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
1262の回答 すべて表示
No sound during calls - Comes and goes
So I have a strange problem no on my iPhone 7. Suddenly out of nowhere it started using longer time to set up calls. And when the call connects, it gives no sound for me or the person im calling. Totally quiet. Does not help to use speaker phone or headset. Then if I try again some time later it will suddenly work as normal. Then it can stop working in the Middle of a call with some strange noises first. I have had the screen changed before, but that was a few weeks ago and it had no problems before. I also tried another screen to rule that out. Also that does not explain the mic not working either
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
PCラップトップ用バッテリー
An easy fix for a big power boost.
ショップを見る
PCラップトップ用バッテリー
ショップを見る
2回答
選択されたソリューション
I know that the iPhone 7 plus has an audio ic issue (motherboard audio chip). Im not sure if it affects the 7 in the same way, but it sure sounds like those symptoms. The main way for me to know it’s that chip is if it takes longer than normal to boot, the touch is laggy, the audio issues you explained and or it gets hot while charging in the upper right where the motherboard is. Are you having any of the other symptoms?
この回答は役に立ちましたか?
スコア 2
コメント:
Thansk for pointing me in the right direction. I had a repair shop change or repair the audio ic chip and has not had any problems since.
による
Great news. Glad that you were able to get it fixed.
による
コメントを追加
Who solve this problem
この回答は役に立ちましたか?
スコア 0
コメント:
Any reputable phone repair shop that does board-repairs / micro-soldering for iPhones.
による
As @benjamen50 says, it was a repair shop that does micro-soldering that fixed the problem for me
による
コメントを追加
回答を追加する
peterhso さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 103
