Is the daughter board the same in the edge as it is in the s7?
I've got an s7 and I would like to know if the daughter board is the same as the s7 edge.
The daughter boards are different throughout each Samsung model. You would need to get a daughterboard specifically made for the s7
このアンサーは役に立ちましたか?
Like as said by others, the charging port daughterboard is different from edge and non-edge models specifically on the two touch sensitive buttons used next to the home button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 47
