メインコンテンツにスキップ
5-Inch Portable Vehicle GPS with Lifetime Maps and Traffic (Discontinued by Manufacturer).
Why does my device not turn on unless it's plugged in
It’s actually a Garmin nuvi 2995 but that isn’t listed.
It will only turn on when plugged into the car, my PC or a USB charger, then it works OK.
I’ve left it plugged into a USB charger for over an hour, but it still won’t turn on unless it’s plugged in.
Can anyone suggest a fix ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
are you sure that is the correct model number? I can't find anything about a 2995 model
さんによる
I made 2 mistakes, it's a 2559 and, I thought charging it for an hour would be enough, it wasn't.
Charged it overnight, all ok now. Found out where to buy replacement batteries though.
Thanks for the help.
さんによる
I have the same issue with a brand new Garmin ETREX 22x.
さんによる
I have that problem with my Garmin nuvi55. Bought a new battery & still have the same problem
さんによる
コメントを追加
2件の回答
最も参考になった回答
Your battery unfortunately has probably gone bad google the model number and see if its repairable lucky in 2018 theres a video for everything. I don’t know if Ifixit will have parts for it try ebay if not look for good vendor.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My mistake, I thought charging it for an hour would be enough, it wasn't.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Frank Edgar さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 1,964
