メインコンテンツにスキップ
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
56回答 すべてを表示
power loss when accelerating
I need help I have a Ford Mustang GT 2004 and the problem I get is when I step on the car does not react aggressively and begins to pull speeches but at 2000 revolutions takes off is a period of time in which the engine dies. I already change coiles, new spark plugs, filter zagolina, service to the injectors and remains the same as any recommendation would be quite grateful
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Check your compression . Any drop in compression will hurt the performance. Is you car losing coolant? Is it casting any codes ? If so what ? Was there any misfires before you changed out the plugs and coils . If so you may be dealing with back-pressure from the catalytic converter. Raw fuel in the converter can cause it to plug and a plugged converter kills power . Also do you have an aftermarket tune on the car . Change out the air filter as well so it can breath Just a few things to look at . Hope this helps
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
it acts like tractioin control it takes off better if I turn it off
さんによる
So what’s the problem? What exactly do I need to fix if I changed my spark plugs and nothing changed oil changed. After market pipes caused my Cadillac was clogged
さんによる
コメントを追加
回答を追加する
José saracho さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 45
今までの合計 2,393
