メインコンテンツにスキップ
Sony CFD-S05 CD Radio Cassette Player was released in 2010, and has the CD-R/RW playback function.
I'm getting no audio from the unit
There is no audio coming from the speakers or the headphone jack with the radio, cd or tape. Everything else appears to be working.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
These units use an IC for the audio amp. With your limited description, I would suspect that this amp has failed. This can be fixed by replacing the amp IC. These ICs are readily available as they were used in many similar devices.
Dan
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thank you, Dan. What other information might you need to be sure? The unit had been working just fine, then one day my wife tried to use it and there was no sound. Nothing had happened to it, the audio just stopped without any obvious reason. Also, I now have the unit apart and have located the ic amp. I have looked on line for one and so far am not had much success trying to find this one. I appreciate the help!
さんによる
Post the number on the IC here please.
さんによる
How can I locate the IC Amp? How do I differentiate the IC Amp unit from others on the board?
さんによる
コメントを追加
回答を追加する
Duane Mitchell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 4,297
