メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
681回答 すべてを表示
iPhone 8 was stuck at 1% now won’t come on.
So I got a phone with a report from one of my techs. The report said after a battery change the phone was stuck at one percent, thinking it was a defective battery she changed it again and now the device will not power on. Screen tests fine, batteries tests fine, charging port tests fine. I trust the tech to be honest and I did find an answer for the “Stuck at 1%” issue. I looked at the component the post directed me to and it was pulled from the board but I also noticed another chip that was broken. A silver like chip just to the left of the RV3C002UN chip by the battery connector port. I can’t find what component this is without a schematic and I cannot find the schematic. Could anyone help me find the name/number of the silver component?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
In general, a shiny glass component is usually a diode or a MOSFET. Check the screen capture of the iPhone 8 Plus schematic below. There is very little difference between regular and plus models on the basic circuitry.
このアンサーは役に立ちましたか?
スコア 2
コメント:
Thanks, I really appreciate it. I’ll look into it as soon as possible and let you know if I can find it.
さんによる
So i believe it is a TVS but I dont want to post the number/name of the component until I am %100 sure that’s the component that was damaged. Customer is becoming anxious, not sure if I will still have the phone by the time the part comes in. Very fine time limit I am working with lol
Thank you so much for the information and schematic but I do not want to mislead anyone. Will have to update you when it is confirmed. I do apologize.
さんによる
Were you ever able to identify the name of that shiny glass component?
さんによる
コメントを追加
回答を追加する
Blaked89 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 515
